[ROM] SkitziPak Hero S/Evo Design
ust some help for anyone.... if you use htcdev bootloader for EVO design. I did the whole process and it killed my network service...don't freak out though if you re-lock it, your service comes back. Freaked me out for a minute but figured it out just a little advice. Plus its useless as of now because there aren't any roms available for HTC EVO design as of now
HTCDev is HTC's own website for providing a way to unlock the parts of your bootloader that aren't semi-open source, IIRC. You probably had the battery cover off after you did it. Those contact points on the back of the cover are part of the antennae, or at the very least effect that way. I think you probably just relocked it when everything was fine to begin with.
I just made a somewhat stock deodex rom from a current backup and flashed it just fine to deodex my phone and allow me to apply some theme modifications. Also, just learned about Script Manager and V6 Supercharger script, 3G Turbocharger script, and Kickass Kernelizer script. Ryandarei(sp) at sdx and xda told me about it. Works pretty flawlessly. I can definitely notice the difference in speed and snappiness. The V6 script says you can bake init.rc into a rom. If I can figure out notification bar transparency, I was thinking about asking another guy if he wanted to put our heads together to develope a rom. Wouldn't have a flashy OC kernel, because we're not that smart, but if 2fast gave us permission we could probably add the Design's WiFi and Wimax modules to make it fully compatible with the Design. I might be able to commit enough time to do it. I'm no dev or anything, but I think it'll work.
Plus, it won't be too much longer before it gets ICS, anyway.
Sent from my *rooted* Evo Design using Tapatalk.
Reactions: falepopoteo
Someone might have already answered this question but I'm not sure. After installing the pack my text that have pictures attached won't send. My phone tries for a while then it says unable to deliver message. Any help? Thanks.
Looking for ROM sites for thiw li'l ph44100
sdx-developers.com R2 saunters on...
Forums are gone from vaelek.com/category/site-news/
2fastroms.com now points to a windows hijacking site
(Linux wins another round against lamer spamware!)
park.above.com/jr.php (cut)
s.arclk.net/tr?id=d0ebdc82d0fa627207d136aed632e2b6ca1682f4.nr
247tech.help/crt/us_seg1302/us_lander1/
(if you want to block 'em into your hosts file)
hincapie
