scootincivic
- Feb 16, 2011
- 162
- 14
- 0
I haven't had any issues either with market apps.I haven't had that problem, did you wipe after installing?
Sent from my VM670 using Tapatalk
I wiped cache , data, and dalvik cache before and after wiping.I haven't had that problem, did you wipe after installing?
Any help please!? Im tired of that stock virgin ROM with all that bloatware slowing my phone down D:
I tried again and it keeps saying that file isnt signed, or whatever.
One issue I have been having recently (not sure whats causing it) is my SD card will randomly disappear. I can either restart the phone or I can unmount/remount the card in the settings (does not always work.)
I'm still using the stock 2gig card atm, so I'm going to try and switching it with a newer 16 gig one and see if the issue goes away.
Anybody else have similar issues?
I have installed the everything as I should and everything is fine. I want to try the new AOSP 2.3 mod over at XDA, it looks like it requires a different recovery to install. Can I return to Xionia if I install the other recovery or will I need to change the recovery each time I want to change the ROM?
So i overclocked the phone last night as i mentioned in my previous post. When the phone was at 0% i plugged it in to charge via USB port from my computer and went to sleep. 8 hours later i got up, and an hour after that i unplugged the phone (9hrs total charging). It only got to 30% huh? usually this fully charges it.
So i plugged it into a wall charger for a few more hours to get it to charge faster. For at least an hour and a half i was listening to pandora while it was charging. Barely got anywhere, i think 54%. I came inside and plugged it into a wall charger for another hour then it got to around 70ish%. Left to go buy some stuff for an hour and left the phone on the car charger during that time (yes, it was still charging) and i come back and only 77% now?! Whats going on? This phone doesnt want to charge now!
Jmel, im gonna try your profiles you set on SetCPU. They sound good to me and im also going to try y5 battery saver. Lets see how battery life goes...assuming i figure out this charging bug. I have the nagging feeling it was clocking up to 806 while charging (also had GPS on for some reason) and im hoping this wasnt negating the charge it was receiving.
update: appears to still be charging painfully slow.
Make a nandroid backupI have installed the everything as I should and everything is fine. I want to try the new AOSP 2.3 mod over at XDA, it looks like it requires a different recovery to install. Can I return to Xionia if I install the other recovery or will I need to change the recovery each time I want to change the ROM?
Have you installed a custom recovery? The rom won't flash with the stock LG recovery.
