[ROM/THEME] MIUIHO-ROM Idea [Updated 8/31]
is there anyway to apply .mtz themes?
If you're using MiLocker, you should have a folder on your SD card called MIUI. In that folder, there's a folder called theme. Just put the .mtz files in the theme folder.
There's a thread on XDA, I'll have to look it up later, but they're porting .mtz's for the Optimus family screen resolution. There's quite a few now.
hey guys, i installed the rom from my sd card, as well as the gapps, but when i turn on my phone it just stays on the miui android screen screaming DROOOIIIIDD at me, and getting me pissed. HELP?
I don't know if I'm retarted, but that one also f***ed up for me. It basically starts the rom, and then freezes on the screen that says MIUI, followed by the word Android. The same thing happened with the MIUIHO rom. Can you possibly give step-by-step instructions for installing the link you just gave me to my feeble mind?
Both these ROMs are incredibly unstable. Flash a standard IHO ROM.
Sent from my LG-VM670 using Tapatalk 2 Beta-5
Can you atleast give credit to the dev over at xda that actually built this? This was made back when I was doing the Xperia collab with sweat
If your flash this rom , or the other one please give them some time to boot, dude to miui it will take a little longer the your stander iho builds;)
Sent from my VM670 using Android Central Forums
anuragkushwaha2025
