[ROM] Uncommon Sense (v1.0) Release!
The only kernel I tried with this ROM is KiNgs BSF #5. I was experiencing a lot of chop and my battery was draining at an alarming rate, so I went back to stock and that fixed it. I haven't tried any Hydra's yet, but if someone does and gets good results please speak up!
I'm running Kings BSF #1 (which works great on SkyRaider 3.1RC3) and also noticed the battery was draining pretty quick. The "Screen Off" profile in setCPU seems to try to fight against this battery drain, but as soon as I unlock the phone and start playing with it the battery goes down like there is no tomorrow (I have the scaling set to "powersave" too). I really like this ROM so will have to switch back to the stock kernel until I hear from someone who is getting better battery life with another kernel.
I am running King #5 also. I am using SetCPU and clocking it at 998 (stock) but getting good battery life so far. I have been on several phone calls and have used the phone heavily so far today, something about a new ROM and testing everything out makes me burn through the battery somehow. :D Right now I am sitting at 60% battery after 5 hours of heavy heavy use.
Anyhow, my settings on SetCPU are 998 on-demand with triggers at 70% at 884 priority 25, 50% at 768 priority 50 and 25% at 614 priority 75. Also have temp>43.1 to 768 priority 78 and screen off at 460 priority 100 profiles set.
I did test some today at max speed (1.19) and ran into issues with reboots and choppiness. Dropping it to 1.11 made everything smooth again and stopped the reboots but I reverted to the 998 to conserve some battery after testing.
I ran into the same reboot issues with Virtuous and Kings #5 at 1.19 but flashed to a hydra to fix that issue. It seems the batch my phone came out of doesn't handle full throttle too well.
I ran a quadrant at 1.11 and scored just south of 1500. At 998 I scored 1300-1375 over 4 tests.
EDIT: Edited 1.15 max speed to 1.19 in the red above. I may test at higher speeds than 1.11 later tonight.
Loving this so far. Only one question so far.. can you change whats on the dock at the bottom of the screen (Phone, apps, internet) i dont use that stock internet and would prefer something else.
Thanks
kernel
To the poster who asked about the hydra kernel, I am using the #1 hydra kernel. I think it is the undervolt overclock? It's been stable but I did also notice the battery usage seems up from the same hyrda kernel and stock-rooted-rom.
Also, as someone else saw, I've seen the sound slider vertically oriented in landscape once when I unlocked it. I also had the browser quick die on me two times while at the google search home page - it was suggesting search words as I typed and poof! it was gone.
I am also running the #1 hydra kernel with this ROM. Running great so far for me. NO complaints.
The email woes (notifications for HTC Mail not pushing through) are back... :/
Can you post or PM the link to the hydra kernel #1? Thanks!
So I am really digging this ROM. It is especially cool to me since it is the first time I've done this. Nice job to the developer!
I really like the look of the smoked glass widgets. I installed Pandora and realized it just doesn't match all that well with the ROM's widgets so I did a search for a smoked glass Pandora widget and I found this:
Smoked Glass Pandora pulled for your pleasure! - Page 12 - Droid Forum - Verizon Droid & the Motorola Droid Forum
There are about 10 different ways explained on how to get it loaded in that thread, they all seemed to do the same thing just using different apps (Root Explorer vs. Terminal Emulator vs etc.).
Hope this is helpful to anyone looking for that extra bit of consistency across installed widgets.
Is there a way to change the lock screen when getting an incoming call to something like this:
I want it to match the home screen one when turning on the phone.
Thanks
Yeah, I asked the same thing, he said earlier he was going to release some patches to be able to change that up. No ETA of when that might happen, but I can live with it the way it is for a while.
Wow this is pretty good , 14 hours and I still at 55% battery left. Also run better than original HTC sense Thanks for your hard and great work !!
Loaded the hydra overclock #1 and I couldn't get past the splash screen. Recovered and tried overclock #2 and I think we have a winner!
This rom is awesome I love it coming from a vanilla rom think ill stick with it for a while
kingteekay
