[ROM][WIP]OptimusWiz[06-07-2012]
Re: [ROM][WIP]OptimusWiz[04-21-2012]
Allright if u can. Also make it zvd only of u can
Sent from my LG-VM670 using Tapatalk 2 Beta-5
building now. but i do not have an optimus s rom to test. using my modified gingerkernel source for the build
Reactions: arnold1997
I'm confused. I'd like to try something new but I'm not sure what we're talking about here.
Yes. You can flash V roms with no problem. Just not froyo roms.
in the first post of this thread you can find a rom, based on mine, all touchwizzed up and pretty.in the past fer posts there was a request to port it to the optimus s, so i rebuilt my rom for it
Re: [ROM][WIP]OptimusWiz[04-22-2012]
SO ARE THERE ANY BUGS in the new update. I want to flash a new rom because ICS 2.3.7 is not working and Harmonia 2 and IHO Backside even with Green Machine theme is boring. Your rom looks cool so before I flash it, i would like to know the bugs if any.
The only bug is really minor like popup messages are a bit deformed u really cant notice it unless u pay attention
Wow this is great! I'll try flashing it soon when I have time.
I took a closer look at the screenies, and I noticed that there are no toggles in the notification dropdown. Do you plan to add those soon?
There are i just disabled them. They are already enabled when u boot
I am absolutely LOVING this rom. I have tried SEVERAL over the past few months and nothing has satisfied my needs, but this ROM just rocks! It is also surprisingly LEAN. I now have 180mb total with 110mb free after flashing rom and installing all my apps.
One small question, and it may be a dumb question, but how do I get apps to stick to the bottom quick launcher? After I flashed the rom, I have the "messages" and "app drawer" buttons, but I can't add any more app icons as the trash bin pops up and it just deletes the icon from the screen instead of adding to the quick launch.
Otherwise, great ROM! I highly recommend this one. :)
pmm09
