[ROMs]StockOV v2.2.1 - OverDrive v2.2.2
Re: [ROM]StockOV OverDrive V2.2.1 - 2.2.2
nice work lil brother might try this on the GF's phone if i can pry bobzhome's CM7 out of her hands lol
Thanks big bro, I told you I been putting in work!
Make you proud? I lean from the best.
I love CW7,
but I like IHO better
Does the accelerometer work with the bumblebee kernel? The xionia kernel is not an option for me too buggy.
I've tried and screen rotation is broke with bumblebee kernel. My advice wait till the dev gets his kernel up .
Sent from my Quattrimus V
Like I said, having broken accelerometer is better then having Buttons set up like Opitmus S... ew..
I'm almost done, just need to tune it, it keeps jumping on me a lot....
Well there is a button remapping app i forget what it's called but the xionia kernel has other bugs like being a little more sluggish than kernels based off lg source and it also has battery issues which is why i stopped using it. I get my iphone 4s 32gb next week so i guess it really doesn't matter at this point anyway as i am going to sell this phone with a 16gb sd card.
Does your power button work? I'd buy your phone with my taxes haha
theres also a button map zip on the forum someplace just for that. be alot of digging to find it so.... i say wait for the kernel lol
The keylayout is in system/usr/keylayout
you can edit it with es file explorer or adb pull and push it or copy it to your sdcard then edit it on your computer and then put it back with es.
Reactions: Redbaron2005
hows the new kernel coming??? can't wait to try the 2.2.2 since my phone is originally 2.2.1 it'd great to see this NEW froyo Roms ,thanks :)
I would like to know if the latest version of your rom (v2.1) is based on stock 2.2.1 or stock 2.2.2. Your OP confused me a little.
Sorry I been busy with things,
the latest version of my ROM is 2.2.2
Working on a kernel alone is frustrating so I'm trying to port one over much easyer
I am on my way to de-odexed 2.2.2
Lots of other things in store. Keep an eye out. I do have a crazy life where anything happens, or I might just disappear for a while, come back with GingerBread! You never know.
THANK YOU for the help about the key bindings
Overdrive and hormonia 1.7 are the most up todate froyo roms!!!!
LiveBarney
