how do i convert my rooted ec05 rfs to EXT 4?
If you can post a link I'll take a look at it.
***SORRY, AIO v2.04 IS CURRENTLY BROKEN FOR EB13, FIX IS COMING ASAP, USE ONE CLICK ROOT FOR NOW***
***WARNING NOT TO BE USED WITH ANY SUPPOSED LAGFIX, IT WILL SCREW UP YOUR SYSTEM AND YOU WILL NEED ODIN TO RESTORE***
How come procedure 2 leaves out the info on run.bat and running the one click for Ext4? I just ran through the process and flashed syndicate v1.1(from stock EC05 rooted) and all is working. Thanks again for all the work you guys do.
I am coming from rooted ec05 stock....can u just give me. Quick bulletted list of the steps yu took to get to acs ec05...thanks
No deodexed stock version of EC05 available yet.do we have a deodexed version available yet?
and i'm running eb13 with the ec05 modem. flashed in odin. the rom i'm using (SRF 1.1, wish i was on 1.0.3 still but w.e >.<) works fine. will i be able to flash other roms that were designed for eb13 onto it, or will the different modem screw things up? (ie-if i wanted to say, go back to ACE or a similar pre-ec05 rom would it work, or should i just port the parts i like into a newer rom like i've been doing?)
So use Mybackup root and then try the Odin/factory reset way?
If all fails, use Clockwork backup to go back to EC05?
---If I go back to EC05, does my file system stay if I change it to EXT4?
1. Download One click root EXT4(credit K0nane) here [ROM][ACS] SyndicateROM Frozen 1.1.0 (Takiya) :: EC05/1.3ghz/NoCheckboarding :: 3/27 - xda-developers. See post #2 installation notes.
2. Download the rom you want, I recommend syndicate v1.1(because it worked for me)
3. Place rom on SD card
4. Disconnect phone from computer
5. Go setting>applications>development>enable usb debugging
6. Extract files from oneclick.zip to a folder
7. reconnect phone
8. open recently extracted files, double click on the rub.bat file, when cmd prompt comes up hit enter
9. let it run in may take several minutes, your phone will restart.
10. shut off phone
11. Boot into CWM (use the vol down + camera + power method)
12. It will back up and convert to EXT4....this takes close to 10 minutes with back up.
13. When is finishes using CWM, select install zip from sd card, select EC05 rom, install.
14. Restart
Notes: If it doesn't work perfectly try reflashing the rom.
Notice the directions are the exact same as the first post of this thread, only difference is when you finish boot into CWM then flash a rom. I did not have luck flashing the bonsai rom and have not tried any other.
