JimA Well-known member Dec 4, 2010 255 8 18 Apr 1, 2011 #1 I did the rooted gingerbread. Now when I press anything in my contacts, the app closes. I can't dial or text through the app. All I can do is use the dial pad. Did I do something wrong?
rpmm70 Well-known member Sep 19, 2010 103 10 0 Apr 2, 2011 #2 Did you freeze or remove any bloat apps? I had this problem because I froze the blur_yahoo.apk. If not, you will have to factory reset.
F Finsol Well-known member Oct 28, 2010 142 16 0 Apr 2, 2011 #3 WIPE data and cache a few times in recovery.
JimA Well-known member Dec 4, 2010 255 8 18 Apr 2, 2011 #4 rpmm70 said: Did you freeze or remove any bloat apps? Click to expand... That was it. Thanks.
D Dueyduck Member Apr 26, 2010 12 0 0 Apr 13, 2011 #5 WHich app caused the crashing? I froze bloatware as well
