Rooted. Now need a ROM
Yes, I ran it for about 28 hours, which version are you on? I flashed the nexusMod2.0aospUI version and everything ran smoothly, no problems or glitches but it was still a little bland for my taste. I flashed back to sky ics, I like the fact I get nightly updates on ics, and all the mods you can download and add separately for a custom user experience, ics also has a really sweat camera hack, takes higher quality pics and vids and has a higher sampling rate which improves the audio when using the camcorder greatly.
[ROM][UCKJ2][AOSP Like] NeXusM0Dv2.0 [1/16]
That's the title on XDA. I use the TWLAUNCHER because i don't like the dock and the vertical scrolling app drawer. He's going to be adding the stock battery soon, so I'm excited for that. He has said that he tries not to update every 24 hours, but when he has enough for a full wipe (which I appreciate).
I may try ICS again, i just don't care for all the neon colors and all that. If rather not update every night though.. AND i can't run beautiful widgets with ICS. Force close every time.
How much different is it from stock?
Im currently running rooted stock rom and so far it suits my needs.
I considered the Sky ICS Rom but the constant *update is a little turn off. I appreciate all the dev's work though.
Does anyone know of a "Safe List" of bloat that can be removed? Just rooted and would like to clean this thing up a little, but I don't want to spend all day re-installing .apk's. :-[ Thanks in advance!
araelbenjie
