This is a no go-
After installing SimpleRoot- and then Rom manager, ROM Manager does not work at all-- no functions work
I redid the entire process- very slow-- exactly-- it all went smooth-- no errors-
Rom manager - 2.5.0.3 will not work- will not install SteelRom, reboot, or do anything at all.
Phone is rooted for sure as titanium loads etc etc
So if anyone has advice pls help as I need a phone that works with all my apps and contacts-- and it is getting tiresome restoring this stuff
This is a dbl post from the thread mentioned above as I am getting a bit frustrated hitting a dead end again and getting no answers yet
Have you tried clicking Fix Permissions in Rom manager?
If Steel doesnt let Rom manager install use another rom
if you cant do any of this you need to go back and ReRoot
Do you have the superuser app installed?
not sure where i can tell u that--Does Rom Manager have permissions?
i do now.
when I run Titanium or Rom M. I assume superuser is supposed to log the event etc, and show a popup for a root SU -
but that is not happening-- log and apps is empty in SuperU
