Rooted. what next?
thx. got my swype back. i really appreciate you and everybodyelses help but i have one more question about the ROM: when i plug my phone into my PC via USB, i have a thing in the status bar to click which takes me to a screen where i can mount my SD card to my PC. when i click on this after installing this ROM nothing happens. any fixes or workarounds you know of? thx
Not sure if there is a fix for it, but you can get to the USB Storage screen by going into enabling or disabling USB debugging:
Settings>>Applications>>Development>>USB debugging
If you need that checkbox checked, just press the back button, check it (or uncheck as needed), and it will take you back to the USB Storage screen.
araelbenjie
