Rooting problem, need help quick
WStanford1976
I have a Skyrocket running 2.3.6 I have tried every option under the sun.
Drivers are installed, ran every program it seems...and nothing. Every time i run the program, it starts off fine, recognizes the phone, Gingerbread...starts the process..then says that all the files could not be copied, read-only files. and No root. Ive tried it a hundred times. I have debugging on, mass storage on and unknown sources as well. Ive run out of options. I ned help...thanks in advance
bohanvo2
