Rooting/Roms Question..
Also i'd like to input that the Recovery i use is RA ... so after simple root i went ahead and did, How to start over: Fully rooted stock 1.47.651.1 in one shot (no adb!) - xda-developers
only because for some reason i had an old software number installed that was like 1.17 rather than 1.47- that may not be the case for u but just incase it is, thats the route i took...
Step for step- great success and bam u can start downloading some pretty sweet roms :)
SO this happened to be the case for me after simple root, doing those steps now. Thanks for providing them.
Any roms you recommend?
no problem, i hope all goes well! the rom i'm currently using is... [Kernel]netarchy-toastmod, with an FPS 'fix' for Epson AND Nova - Version 3.6.4 - xda-developers
Revision 3.6.4 - General Population Build
I'm big on the fps issues the Evo had, this completely fixes it, it works wonderfully.
For more roms goto: EVO 4G Android Development - xda-developers
enjoy =)
enjoy =)
Hey tbistONE,
Quick question. Since I already have fresh on my phone, using what you suggested above (I do want to get rid of the FPS cap) would I have to get rid of Fresh or does this work similar to the patches on WebOS where you can have multiple?
In that case I'm assuming you wouldn't boot it using recovery mode.
Hey tbistONE,
Works for any 2.1
Yeah but my question was after I have a ROM on the phone, how exactly do you install these 'patches'.
Excuse me for using WebOS terms.
Your fine, I'm guessing your talking about the fps fix kernel
just flash it like a ROM
PITA the way titanium back up makes you have to click through every app install... I think I might go back to MyBackUp it just did it automatically without asking me for authorization for every app.
Titanium doesn't make you do each one individually. Go to menu,then select "batch." Tons of options. Not sure if it's available in unpaid version.Well worth the price, tho.
Thats the funny thing, I was using the batch operations. It didnt have me select each app after I told it to select them all, it just had me go through the App installer for each and every single one. PITA, but maybe I did something wrong.
When I used MyBackUp it didn't do that, it just installed them all without asking me to click anything.
Yeah, just go back to stock from Unrevoked and your good
I just read over on XDA that I can do it right over. Whole reason I'm trying is because I want to run titanium backup and it tells me I'm not root. Every other root required app is working fine. As is mybackup..
When in Recovery mode i get an error when i go to apply sdcard:update.zip
E:failed to verify whole-file signature
E:signature verification failed
installation aborted.
does anyone has any suggestions to fix this, im just trying to flash a new rom.
Which recovery are you using?
Clockwork won't flash it if it's not signed
but amon will
Iknownothin
