Running 2.1 RUU & MLB AtBat 2010 Issues
packfan909
7
Hi All,
Anyone out there running the 2.1 RUU and purchased MLB AtBat 2010? It worked on 1.5 but now being on 2.1 there is no option to download the app in the market. Anyone have access to the 2.1 apk for AtBat?
Has not been an issue as I have not wanted to listen. But as the season moves forward I would like to enjoy what I have paid for.
Any insight is appreciated!
Thanks
Its a protected app and the RUU can't search the market for those since the ROM isn't official and doesn't have correct keys that allow protected apps. What you can do is repair the bootloader and flash option 2/3/4 and then flash the market fix or flash a ROM like Damage Control which has the fix built in. Unfortunately, you can't flash the fix with the RUU cause you have the stock recovery image, not a custom one for Sprint Rooted phones.
So once Sprint and HTC release the final 2.1 update this will resolve the problem? I can wait. I usually only pay attention to baseball during opening week and then late June forward.
Thanks!
Yeah... but there isn't a guarantee you'll be able to get the update with the RUU leak, you would still need to repair it when it does arrive (Just an FYI).
Thanks, I will burn that bridge when we all get there. Which might be a while. ;)
Enjoying 2.1 so far. Even if my baseball habit is not being met.
bogorshop
