S note Help
G3TCASHM0N3Y
249
Hello, just got the Note and loving it. So in note, I know how to move images into the note area, but is there any way to move them again if I put it down, write some more, then want to move it?
Sent from my GT-N8013 using Android Central Forums
You know, this is one of those things I struggled with and when I accidentally found the solution, I just had to shake my head. Simply hold the s pen on the graphic for a very long hold. Don't move it around because then it thinks you want to write on it. But a very long hold will give you the frame around your graphic to move or resize it. If it does draw on it as you're holding the tip on it, the marks will disappear when the frame around the graphic pops up.
shira
