S Pen problem?
hughie1987
Active member
Jun 21, 2013
32
OK so I keep trying to use the s pen when the screen is off and it doesn't seem to want to write. Like it will show the white dot where the pointer is and I can select the pen or eraser with my finger -_0 so this is my second day with it what am I or did I do wrong lol
When I first got my note 5 this feature was turned off by default. I had to go into settings -> s-pen -> turn on 'screen off memo'.
Sent from my SM-N920I using Tapatalk
Mine is on already by default it was the first thing I looked into
What happens when you write in the screen?
Just an fyi, for the screen off feature, the screen is black and the writing is white.
Posted via the *Note 5*
Nothing happens the screen stays black but the icons appear and it doesn't write. I've had it write 3 times that's it so I know what it looks like :p
Does it work when the screen isn't off, like in S-note? Do you have a really thick screen protector? Do you have a case with a magnet? Have you tried replacing the pen tip?
I have no screen protector or case yet an it just did work when I tried it a min ago it let me slide the page to s note an open it and write. Also I just turned the screen off and it let me write after I took the pen out. So idk what's happening
Are you writing with the pointy end?? "That's a joke son" - Foghorn Leghorn :-!
Try replacing the tip with a different one if it keeps acting weird.
tao17
