S-View case for the S6 edge
There is for the Galaxy S6, but not on the S6 Edge page, its possible you could use it though.
I thought that myself, but I am curious if the edge notifications conflict with the s-view app, and is why it is only listed for the non edge version.
Nope, no S6 edge S-View case (I asked at my local Samsung store). It was a massive shame when I found out but not a dealbreaker.
No S-View Case for S6 edge now. But now there is a Flip Smart Case for S6 edge. You can refer Samsung official website. But it is a little expensive.So If you like it.you'd better buy one from the other place.
Yes, there is one but it's not like what people are use to seeing. It also does not function as well.
https://forums.androidcentral.com/e...s-accessories%2FEF-ZG925BBEGUS&token=zNCTxiqV
Sent from my Galaxy S6 Edge via the Uncarrier
Don't buy this. It scratches the screen so bad. Samsung acknowledged the issue and are looking into it. They even said to stay away from the Clear View Case for now until they find what exactly is causing it.
Sent from my green emerald S6 edge
Agreed, don't buy.
I just posted because people kept saying there isn't one, when in fact there is.
Nautius Maximus
