S Voice not working
I was having the same issues after a few days of using my note 4. after much trial and error I found the problem! It has to do with an app called keeper I disabled it cleared the cache and everything works perfectly now
Anyone having problems with S voice?
When I speak a command all it does is type out what I said (voice to text) but no action. After it types out what I said it goes back to asking me for my next command.
I don't see a settings to change anything that may fix this, any suggestions?
Also, no matter what setting I have , it never gives me any voice audio feedback.
Not working for me either... Google now is great, but I like having the option to use S-voice..
Tried all sorts of thing... it just doesn't work...
It did the first day I had the phone, though.... :-(
...sent from a phabulous HAL 9002, a Sprint Galaxy Note 4.... ;-)
Did you disable keeper?
Don't think have that..
. don't even know what it is. :-)
it's a new app has been installed on a lot of newer Android. Go to your application manager and disable it if its there
No app by that name on my Note 4....
I searched the whole "all" app list, no "keeper" anywhere....
I am having the same issue. No voice feedback on my note 3, so I can't use my voice out text to speech from my headset anymore. No 'Keeper' on my device either.
tetee3000
