- Feb 6, 2017
- 98,928
- 15,586
- 113
My bad. I didn't have the free version installed. Got it now, but my Status and Nav bars are still gone.
Oh man
Maybe it's not updated to latest Android version, you on Android 13 yet?
Oh man
I would try itAndroid 11. I blocked Android 12 update because I don’t want to deal with a new UI. I've been wondering if installing it might fix this problem though.
I would try it
Like a factory reset?OK, I installed Android 12 plus UI 4.1 and 3 security updates, still no Status and Nav bars. I guess the next step is to reset and start over?
Sent from my Pixel 7 Pro using Tapatalk
I wouldn't factory reset at this point , if you uninstall the app does your button return ?Yes. Any other suggestions?
Then try couple things hereNo. I uninstalled it before I did the updates.
Go setting>general management>reset>reset settings
Also try setting>apps>3 dot's upper right corner tap then reset app preferences
Rebooting the device after each one
What if you change from navigation button to gestures do they work then go back to buttons
Then going need to factory reset
Yeah lol ..i was trying to avoid thatThat's what I was afraid of. Oh well, here goes......damn the torpedoes, full speed ahead!
