S20 Ultra -Display Problem
  • Start date Start date
A
Android Central Question
Hi friends , just now I'm using my S20Ultra to playing some games, but it is happening when I'm using the 120hz display, whatever games I open, the screen will become yellowish, but in the 60hz screen, it is fine for everything. Sometimes the display turn to yellowish when I just switch to 120hz. Need help.
S20 Ultra having some problem
Re: S20 Ultra having some problem
Hello, welcome !
No need to make another post as I put you in the correct forum already .
Hi I think this the the problem that I facing, also my device come with the Exynos processor. And yes, that tint gone when I turn the screen brighter.
Yellowish sounds like the blue light filter. Not sure why that would engage with game play, but you might check the the display setting.
Ive read its a possible issue after the April security patch with the exynos version.
https://www.sammobile.com/news/galaxy-s20-ultras-latest-issue-green-tint-on-display/
it is an issue with the latest update (april security), which seems only to affect the exynos version of the Ultra. Samsung hasnt been doing too good with updates recently, causing more problems than resolving them.
DeboracKee
