S23 Ultra - Tap To Answer & HOME UP (Task Changer) Questions...
memphisboy
250
33
28
I am on the S23U and previously on the S22U and S21U.
Is there a simple solution when answering calls to click the ANSWER button instead of swiping to ANSWER?
The only shortcut I found was in the accessibility menu and turning on the assistant menu option, which is fine but the trade-off is having the assistant menu shortcut button on my screen as an edge icon.... Is there an App?
Also: In the HOME UP app in the Galaxy store, anyone else notice that Task Changer is not activating after turning it on... Only the stock task changer sticks.
you could just turn off the accessibility shortcut button. you can do that, you know.
No members online now.
gruptysh
