S3 screen flicker?
Go sms pro and disabling the stock app fid the trick for me it seems! :-)
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
So then this basically confirms its DEFINITELY a software issue. Lets hope samsung does something about this.
I have seen this issue outside of the SMS app. I've seen it in both Google Talk & Google voice.
I'm thinking the issue is related to having the keyboard up, and not necessarily the text app. You tend to have the keyboard up the most for texting.
For the record, I'm using SwiftKey 3.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Notice same thing here only when texting. Using SwiftKey 3. The flicker is so quick that if you blink you'd miss it. I don't see it typing in Tapatalk. I think it's something to do with sms. If it gets worse, nothing warranty won't fix. Except for the G1, I've never owned a smart phone that I didn't have to warranty at least once; most multiple times.
EDIT: Just noticed it flicker while typing in Tapatalk as well.
Sent from my SCH-I535 using Tapatalk 2
Interesting. So.... Maybe just having the keyboard up a lot, or possibly keyboard specific.
Feel free to chime in with the Keyboard you are using.
Also, please list any apps you have observed the flicker in. Was the keyboard visible?
It doesn't sound like the OP is having this problem, but if someone else comes to this thread with a flicker problem this may help them:
[YT]http://www.youtube.com/watch?v=YBz9oBQ_1tA&feature=player_embedded[/YT]
I get really bad screen flickering when I'm in tab view in Google chrome
Sent from my SCH-I535 using Android Central Forums
I have had it since day one when I type out longer texts in the stock messaging app on my HOX, I use Swift key keyboard too. Don't get when I am typing in things such as this forum though.
Sent from my HTC One X using Android Central Forums
SwiftKey keeps popping up in all these threads. On multiple devices too.
Just experienced the flicker as I typed this reply.
I fixed it. turn off direct call in the motion setting. It thinks you're going up to your ear for a split second
Why would this be happening when people are using Chrome and Tapatalk though? Neither of those utilize that particular motion
After I installed GO SMS Pro and SwiftKey 3 and I disabled the stock messaging app the issue seems to have gone away. Or I have gotten use to it I guess! :P
Try that and report back to us. It is a software issue by the way things look. Plus the stock messaging app is junk anyways. I hate it when it turns my screen on due to a text! Either way. I hope this helps.
amateur_user
