S4 Battery drain by "Android OS" dropping 40% over night
I keep having the same problems with battery not charging, phone getting extremely hot when used or when charging, battery draining from 100% to 70-80% within a little over an hour no matter how much or little it's used in that time, battery decreasing when its used while being plugged in. I have stopped extra apps from running when not being used but do not know what absolutely can not be stopped because it will mess the phone up. Also I have noticed that when I stop apps from running many start back again on their own as soon as I close settings. I am also unable to connect to Facebook and other games when using wifi but connects with no problem when wifi is turned off. Other apps work great with wifi. Facebook and Candy Crush seem to be the ones i have the most connection problems with.
My tab2 also decreases battery when used while plugged up even when it shows it is charging. Any suggestions???????
If you are charging your device, turn it on before disconnecting the charging cable. Then you can turn the device off.
daisy88
