Based on reports of poor audio quality of the S4 with low-impedance headsets (~ 12 ohm or so), I have tested my S4 (SGH-I337) and compared with an S3 . My measurements, using pure resistive loads, clearly show an oscillation artifact in the S4 audio for headphone impedances <14ohm. This problem is NOT present in the S3 I tested under identical conditions.
Note that stock headphones provided with the S4 and S3 have impedances of ~ 35 ohm and therefore won't be a problem. It is my opinion that if Samsung is aware of this issue, they should definitely include in the S4 spec a MINIMUM headphone impedance value of, say, 16 ohm and should clearly fix the problem in the next Galaxy S.. release.
See below for measurement details:
Samsung Galaxy S4: Problem With Low-Impedance Headphones
