S4 Mini: Camera Zoom Problem
ebeskimo
3
Just bought my S4 Mini and love it except the camera zoom does not work. Any help in solving this? Thanks.
Re: Camera Zoom Problem
It doesn't work by pinching to zoom? Sometimes you need to do it slowly.
Also, did through the camera settings and see if an option is available to display the zoom bar while taking a picture.
Thanks for your response.
Zoom does not work either by pinching slowly or by the volume up or down. Does not work in still or video mode. Gives me a message "cannot zoom in or out in this mode" for every mode possible.
Not sure how to get to any camera setting.
I have removed the battery and put it back in. I have booted in safe mode. Nothing helps.
Still have not solved the zoom problem but I purchased an app, Camera Zoom FX, which works like a charm with 30X zoom.
I also had the problem where i could not zoom camera in any mode with my new samsung s4 mini. Also the settings menu wasn't appearing on the camera . I had to reset my phone to solve this problem. Lucky I had nothing on my phone to lose.
Turns out the zoom is not a "Camera Mode" but a "Phone Mode" issue. I couldn't find this anywhere on Google or Verizon's help lessons.
I had the phone in 'Starter Mode". I looked up how to put it into starter mode, followed the instructions, then saw the option for Standard Mode. Walla!
Nice one John!
I tried for hours to 'fix' mine. I'd also did a factory reset, fortunately I was using 'Clone Phone.' Initially is was ok but then once again refused to zoom. I think it was the last update which did it, but can't be sure.
Now we know . . . . .
awesomeness Kociemba!! i just got the S5, and had this same issue OOTB (couldn't zoom, & no 'gear' icon). i scoured the web for hours before i found your reply. on the S5 it's "Easy Mode" (i think, i'll double check), but sounded the same... as soon as disabled it, i have full camera functionality!
thanx Kociemba!!! d-(^^,)
Chers amis,Moi aussi je n'arrive pas à zoomer sur mon note 4 que je viens d'acheter. Impossible sur tous les modes de la caméra. Thanks tout help me
yanis
