S5 and wireless charging card?
skullfreak
111
Does anyone know if I can use a wireless charging card in my s5 and will or can they damage my phone?
Are you talking about the charging receiver that goes between the battery and the back cover that you can buy on Amazon or Ebay?
Sent from my SAMSUNG-SM-G900A using Tapatalk
My co-worker bought one off of Amazon for his S3 and he likes it. He's had it a few months now. He says it does get warm when it's charging but that might be normal for wireless charging, I don't know.
I've been looking at them for my S5 but quite frankly I'm scared to use something not manufactured by Samsung for fear of damaging my phone. I wish Samsung would hurry up with those charging back plates before I break that annoying little USB cover off.
Sent from my iPad using Tapatalk HD
It should work, it worked on my note 3. Although the Wireless charging back worked better
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3
The N5 gets pretty toasty when charging wirelessly.
With Samsung backing no cases fit.
Maybe a tpu but not very good I had one on my s4
That's what I was thinking. At least with the wireless receivers off Amazon the case I bought will probably still fit. I have insurance on my phone but I like to use a thin case anyway to keep the corners from getting banged up and stuff.
Now I'm wondering if the gasket for water-resistance under the backplate will seal tightly if I use the receiver.
Maybe but I hate this new 3.0 charging it's hard to plug in at nite with no lite on.
You can use a standard microusb 2.0 cable.
Rtisokjoala
