- Nov 18, 2014
- 5
- 0
- 0
When using an app or Voice Recorder the Mic works fine. When I plug a headset in, the Mic cuts out... Do I have to use a headset with built in MIC... I want to use headset to listen and built in MIC in phone to speak. Thanks...
Hi,
I know is a bit late for the answer but I own a Verizon GS5 (Android 4.4.4) and it still faces this issue. The solution was to install the application: SoundAbout.
In the APP go to "Connectable Devices" > "Wired Headset Settings" , and there uncheck the box that says "Wired Headset microphone". After that go to the main menu of the App then toggle the SoundAbout Service (change it from ON to OFF, and from OFF to ON to force the detection).
Regards.
Hi,
Regards.
