s5 burning through battery in 4 hours with little usage
Dan Gillmore
I just picked up my s5 two days ago, and the power goes from 100 percent to 20 in three hours, and says it's got an hour left. I don't have location services on, I'm not running any apps and I have background data usage turned if on almost everything. Is this normal?
No, it is not normal. You should be able to make it through a whole day with plenty room to spare with moderate usage I'd take it to the local store and make them give me a new battery or phone swap since it has only been 2 days. I usually plug in at night with >60 percent left, but I'm on wifi mostly both at home and work.
Two days old? Get it replaced. Posting your question was more work than you should have put into a new phone with a problem.
Qmoitramer
