S6 Edge not Receiving Messages Greater than 160 Characters?
xSlavik
6
Hey guys, so I recently made the switch from an iPhone 6 to a SG6 Edge. I am loving the phone except for one key thing. I am unable to receive text messages that are over 160 characters. I know that once an SMS is over 160 characters, it turns into an MMS. But the thing is, my MMS settings are set up, everything should be working okay.
I don’t know if this matters but this phone is unlocked with Sprint, and I am currently using Rogers as my service provider. I am looking for any solutions you guys may think off, if I cant find any resolution to this I think Im going to have to switch phones either back to an iphone (which I don’t want to) or another Android phone.
I have called Samsung Tech support AND Rogers, and they weren’t much help.
Here is the list of things I have done to try to fix this problem:
-Factory reset my phone, didn’t work
-Configured my MMS and APN settings manually with the help of Rogers
-Sent myself a picture message, received it fine.
-Sent myself a message over 160 characters, received it fine.
-Used the stock messaging app, as well as 3 different ones. (currently using textra due to the simplicity of it)
-When I had my iphone, I disabled the iMessage, also went on the apple website to make sure my phone isn’t linked to imessage. Its completely off
-Rogers said it’s a problem on the other end (contacts aren’t sending messages properly)
-this is false because I wont get any messages from android users, blackberry users, and iphone users. Its not just one or two contacts, its my whole contact list.
-few of my buddies have the S6 edge and none of them have this problem. (few switched from iphone)
The only solution I can possibly think of is getting a different sim card, but service provider said this will do absolutely nothing.
I run a business and I need to be able to receive SMS messages over 160 characters (no I will not use a 3rd party app which Samsung suggested. I need my texts to work.)
If no solution is found, sadly will have to get rid of this phone.
Why Can I Not Receive SMS Messages Over 160 Characters?
Thanks
Re: Why Can I Not Receive SMS Messages Over 160 Characters?
Thanks
SMS is a spec that dictates the 160 character limit.
Why won't you use another SMS app (you're already using third party app Textra)?
ive tried hangouts, textra, go sms and handcent
have you tried returning the phone and getting a new one?
I guess trying a new sim couldn't hurt. Especially if your sim is old.
Tough situation to be in but if those things don't work you may have to get a new phone.
Help me resolve SMS/MMS Issue and I will personally paypal you 5-10$.
Thanks
Re: Help me resolve SMS/MMS Issue and I will personally paypal you 5-10$.
Please do not post new threads for pre-existing topics and/or multiple threads for the same topic. Additionally, transactions outside of the marketplace (physical objects only) are prohibited.
pamatika
