- Apr 13, 2015
- 2
- 0
- 0
While I have no issues on my Ubuntu box, my S6 Edge is not recognized on my MacBook.
Anyone else with the same issue?
Android File Transfer does not seem to work with S6 Edge.
"Could not connect to device. Try reconnecting or restarting your device."
Im also looking for a good non cable way to transfer media between s6 and macbook. Anybody got anything?
Android File Transfer doesn't seem to be compatible with the S6. If you want to transfer your iPhone or previous phone data, use the Switch program from Samsung. If you want to keep using a sync app, use Kies from Samsung.
