S6 Edge Screen Protection
Spigen looks like it will be my second choice if the skinomi doesn't last.
The back of the spigen does not cover the entire phone. The front was a messy install but its fine now. For my money i would have gone with Skinomi. I have always had good luck with them.
Here are a couple pics of the Skinomi, my apologies that it's kind of dark, I had trouble finding an angle that wouldn't show crazy reflection.
via the AC App on my S6 Edge
I found the Galaxy S6 Edge Screen Protector Clear Curved Crystal. It is by Spigen and dry install. Has anyone ordered this one? Thoughts?
I actually ordered it...should be here this week....will report on how it works out. I actually have the spigen flex cover, its clear but you can tell its not crystal...like self healing plastic which im dying to remove...
Hi Raptor007,
Any updates on the Azmer Tempered Glass??? I heard that the people who ordered it, received an email from Azmer telling them that there had been some issues with the glue so they had their orders cancelled.
Has anyone bought Skinomi at a store? mine edge is coming in tom, and i would like to pick this up if they sell them at best buy or att/ any other phone stores.
went with the spigen and I must say although its a good fit on the front the back is the complete opposite really unsure why but who knows. and with the front its a wet install so you spray some solution onto the film and put it on. in the manual it states all the tiny dots of moisture will vanish within 48 hours but they can still be seen. overall 5/10
I got the Skinomi and applied it. It still has the water marks underneath it and like, orange peel-like bubbles that don't affect the clarity of the screen but you can definitely see them with the screen off, like the protector hasn't settled all the way.
Hope all of that clears up. It's only been an hour or so. I know they recommend setting it aside for quite a few hours but that isn't possible.
UPDATE: upon waking this morning, all of the bubbles and orange peeling are completely gone. Looks perfect. The feeling of the protector is not as good as a glass protector, but it is a close second.
I have the skinomi screen protector and it applied it and it's ok...covers the whole screen....the only issue for me is when I try and play a game....that PET film is very sticky.....not glass like....tears....waiting on the Amzer....
I just got the edge, had Verizon put a Zagg screen protector on it with an incipio thin profile case. The phone is fully protected, edges and all. Feels great in my hands and not bulky at all!
Yours tore?? How?
Just got my Skinomi full body skin but I'm confused were the parts that are by the back cover skin go can someone help?
There should be diagrams on the Skinomi site or Amazon
Had anyone received their amzer gorilla glass protector yet? I ordered mine from amazon just about a month ago and it still isn't in stock. No estimated time, either.
Samsung Galaxy S6 edge ZAGG InvisibleShield Dry Full Body
That is what TMo put on my phone. It is not straight at all and driving me crazy! Has anyone tried to peel these off and use a spray solution to reinstall it?
It leaves about 1.5mm showing on the sides and the cutouts are fairly large. I don't think this protector is recommendable.
Thanks for any help!
The likelihood of an acceptable removal and reinstall that doesn't make your phone look like a peanut butter and jelly sandwich is about .0001%. They are simply not made to be removed and reapplied.
Zagg screen protector. They're a little more expensive but they have a dry one. I have one on my edge and I like it.
cotogon222
