S7 Edge ATT Update Released
just received AT&T update a couple hours ago.
Does anyone have a full list of what is included?
I can tell you right now that I have absolutely zero lag when typing. Prior to this update the keyboard was lagging very bad.
It looks like ATT has released two updates so far, the one with the April security patch being the latest.
The one I received first was the previous update. Apologies for the confusion.
I received the update yesterday. I noticed right away that my wifi issues were fixed and the screen and overall response have improved.
Updated today. Lost the ability to unlock the lockscreen with fingerprints. Have to key in the pin. Anyone else?
On the s7 edge every time you restart your phone it will prompt for your 4 digit password. After that you should be good unless you thumb print security setup is wrong.
After this update I've noticed more lag on the phone and considerably worse battery life. Back to that tethered life...
My battery life is terrible now, I had problems with my phone resetting by itself. It would mostly happened when I was downloading videos on youtube, it would just restart. I called att they said there's a new update out try that to see if it fixes your issue. I had 1 reset so far but the battery life is terrible now.
I got the update yesterday. Definitely seems improved. I haven't had any random spit screen activation since the update.
All of you with issues and worse battery life, have you done a wipe cache in Recovery menu? It's always recommend to do it after an update.
Quick reminder please on how to do it for those of us that have forgotten?
Decided to leave it off the charger overnight to check for a difference. It lost a lot more battery than usual almost like doze wasn't working at all...
$700 phone ought to be smooth from the get go. If its not I'm getting a refund
What all does this erase? Is it safe? Why wouldn't this be built in to Android to happen automatically after an update if its recommended? Suspicious of BS here...
Also wanted to note after a few days, my battery life is still not as good as it was 3 weeks ago when I bought the phone.
Ask with a better attitude next time and I'm sure more people will answer and help you.
No BS, it's safe to do it, not a single personal file or app are deleted just OS junk. Why it doesn't do it automatically? Well, ask Google, and even if they does it now (no way on knowing) no harm on doing it again, as most of the time your phone begin to behave strange or not normal, a simple Wipe Cache Partition can do magic.
It's fine if you don't do it, that's up to you, but a thing like this that can take no more than 5 minutes in total to complete, can save you tons of time troubleshooting and also a lot of frustration.
With the massive amount of BS and people on the internet that spew out "information" that they know nothing about, it's hard to maintain a better attitude. Trust me.
I guess I'll do some research into this.
Do the wipe cache for sure. It is harmless and can definitely help.
But also consider a "rogue app" as the possible culprit for your battery problems. Or did you install any new apps recently?
My S7 Edge has great battery life, and it continued after the recent ATT update.
Ashok Dharshan
