S7 edge battery drain from Bluetooth?
Andyvalver
424
Anyone have this problem? It seemed to use a good 2 hours of cpu time the other day and wiped out my battery. I tried to use it to transfer some photos to a print machine but it failed. So I turned off Bluetooth but it drained my battery as if it was some how running in the background.
Posted via S7 edge 😍
Is your Settings>Battery​ menu actually showing Bluetooth as a high battery user?
Yeah. It was the highest. Above display usage. Seems to happen if I use Bluetooth but even after u turn it off it uses battery. Only was to stop it was to restart the phone. A bit annoying.
Marlene
