S7 Edge Battery Issues ! :\
Shams H
12
So I bought the S7 Edge a week ago, the first 3 days the battery was amazing !
overnight usage only 3-4% (8 h)
screen time over 6 h
but then the battery started to drain really fast ,,, the best I could get from it was 4 hours of screen
so I tried to test it and turned everything off, left the phone in an area with good reception, and didn't touch the phone. over 5 hours It dropped from 100% to 87% !
what could be my problem? any suggestions would be appreciated :)
That doesn't seem bad. But then yeah, mine lost just 3% last night. But the difference is you've started using apps. Doze won't immediately work for all apps in the phone so some may have been left running.
I also have an old S5 (more than 2 years), same apps , same settings but drained 7% in the same time ... that's what got me worried
but I guess I'll give it sometime and hopefully it will get better when it learns about usage :)
chzahid600
