s7 Edge getting hot - overheating?
xxstranger
17
does anyone have this problem?
I bought my phone yesterday and ıts getting so hot just after i unlock and use camera for lıke a few photos or to look email/internet
it gets hot next to camera where İ believe processor is. Battery isnt overheating the way i see it in program
I checked temp with cpu programs it shown 34.c and 40-45 at charging. but still i think its not normal after this small use to get so hot. could it be defective and i should take it back?
no ım not getiing any message but ıit gets hot in my hands just after opening camera and taking a few photos. so far i noticed camera mostly makes it so hot at the backside and front. it gets hot with checking emails too but with camera its even more and temp shown was around 34 - 40ish because
even just charging now and google photos backing up it went up to 60.c
@dpham00 does it get hot in your hands just after like using it for 5 min?
hm @ClintRO but İ wonder how can that be normal. İ never got this with my S5 when İ got it new. Did yours get hot like that with small use like mine like just taking a few photos?
Yea.... Quite a bit. I think it was updates and stuff running in the background. Maybe a reboot will help.
İ rebooted several times, even wiped the cache partition and same thing...I think I'll call to the store tomorrow and state my issue
yes İ do. İs ıt anything about it? though I keep getting that sd message that people reported keeps popping up a few times in a day
@xocamaox
I played a game and with game it gets just warm and evenly warm like the whole phone, not like with normal use and photo taking while it gets hot next to camera at the back and front
Mine only got hot as it downloaded all my apps over LTE and installed them. After that it's been fine with normal use and even gaming some.
@xocamaox
This could be an indication of a faulty microsd card or (more rare) card slot in your phone. I would pull it out and try using the phone to see if you can isolate the issue.
My phone doesn't seem to go past 100ºF or 38ºC when charging/gaming/taking video, according to GSam.
okay, but I dont think card or slot can be a problem because i am not even saving to an SD card. It's saving to device
plus like I saıd just taking a few photos it gets so hot next to camera at the back, but when gaming ıts less plus then all phone ıs warm not like when running camera
Give it a few days. Everyone seems to be experiencing this in the beginning. Mine is fine now.
and now it happened today the phone became totally unresponsive. back button, open apps button nor home button worked. İ took a photo and suddenly after reviewing photos screen went black and İ had to hold volume down + power to imitate the battery pull
so İ think its tıme to call my operator
I've had mine since March 1st, and so far it's been lagging a little here and there but less than normal for a Samsung. Whenever I shoot video is gets pretty hot, but no warnings yet. I'll continue to monitor and let you all know if it continues.
Just because you are not saving data to the SD card doesn't mean the phone is not using it. I would eliminate any foreign hardware connected to the phone (sd card) before trying to troubleshoot.
Rukhshan
