s7 edge scrolling issue
victor santos3
3
When scrolling left and right everything seems normal and smooth,but try to scroll a little bit or halfway then stop but keep your finger on the screen,you will notice the apps and widget start to shake or wiggle even though your not moving your finger, have you guys experience this issue?
Not really. If anything, my finger might be making it "shake" a tiny bit. Definitely nothing to write home about.
I have the exact same issue, it's like the touchscreen is way to sensitive and cannot locate the exact area where the finger is. I also have a lot of ghost touches and a lot of times the screen registers a touch when my finger is about 2-3 mm away from it.
right.or a bug in the sofware,i even remove my zagg screen protector thinking it might be causing the issue but nope it's still there,i even tried it on my old smartphones Gs3 & Lg G3 and they dont have the same issue,im gonna try the s7 edge devices @ at&t and bestbuy store and see if they have the same issue,if they do im keeping my device if they dont im exchanging it,my 14 day return window is up today,are you planning on exchanging or returning your device?
vickyy
