S7 issue to move apps sd card
  • Start date Start date
I have the same problem with my s7 edge, have a SanDisk 64 on it and I have the option to move my apps like asphalt 8 to sd card and it said it have been moved to sd card successfully but when I check the folder it is empty and still is in my internal storage... is there any fix for this issue?
change the theme solved my problem but yours is different..
I guess this has to do with the theme. Try just touching the right bottom corner of your screen, it might take you to the next page.
I had this issue with a black theme where i just saw a black bar at the bottom. When I switched to the default theme the option was visible.
I guess its a theme incompatibility.
THANK YOU! I didn't realize the theme I downloaded was screwing up that screen! MUCH better now that I can move some large crap to the memory card! Thanks again!
Go to settings, then applications. Open the app you want to transfer to SD card, it's where you can uninstall apps, look below uninstall where you see storage. Open storage, if the app will let you move it will say change external then go from there...some apps will only work on internal so there won't be the option to move to SD card.....depends on the individual app. I hope I explained so it's understandable. God Bless.
reblkari666
