S7 Vibrate - incoming calls
Sallz06
3
Hi
I have my phone set to vibrate but underneath is an option for phone to vibrate for calls but it is 'greyed' out. How do I select this? Have tried looking for the answer with no luck
I have attached a screen shot if not clear.
Any Help greatly appreciated
Thanks
It's my understanding the toggle only works to turn vibrate on/off if sound is enabled. If you enable sound can you toggle it on/off and see if it vibrates?
Check vibration intensity and ensure that's turned up.
Something might have simply glitched in the software as well, I would try wiping the cache partition.
yes if I enable sound it allows be to select if. On vibrate and mute it does not. I understand mute you wouldn't want it to vibrate, but I would like it to on the vibrate setting.
Vibrate intensity is on full.
Can you advise me on how to wipe the cache partition?
Thanks
fix my speaker
