S7 WiFi &BT problems
Lucy1376
Just got my new S7 Fri. Got it all up and have discovered WiFi slows way down when Bluetooth is enabled. Anyone else seen this prob?
There are a few other posts out here on this forum reporting similar. As a former wireless network engineer it sounds as though the BT is causing some interference on the 2.4 GHz band - it shouldn't though. There are a couple of options to look at other than Samsung fixing the problem if it is BT interference (I've done surveys where BT absolutely kills wifi).
1) If you have a 5 GHz (dual band) radio available, that is easiest. BT operates in the same frequencies as 2.4 GHz wifi.
2) If no options for 5 GHz, look at changing the channel on the wireless antenna. Often times these are set to auto - which is typically very bad, it doesn't pick a good frequency to use. Set it channels 1, 6, or 11 and test each of those out.
I'm running in a 5ghz network I still have slow down issues.
In fact same exact setup as my iPhone 6s at home and no such issues
I'm seeing the exact samething on my Verizon S7 edge. Just got it today. 10 mb/s down when bluetooth is off. Less than 100kb/s when bluetooth is on.
I found mine worked better when I had a Bluetooth headset connected to my phone. Also when I removed the meijer app it started working again. The meijer app needed Bluetooth permission so I would think that other apps that require the same might be the problem. Jm2¢
If you have the Dunkin Donuts app on your phone uninstall it. There is a long thread about this and either there is a flaw in the phone or DD has to update the app.
layahhhh
