s8 battery drain
Mohammad Shebaro
67
Please help my s8 is draining so fast with excessive heat problems... i can't even touch my phone so i use my phone cover inorder to block the annoying heat !
Your cpu cores are running 100% for 24/7.
Some app is doing that, or multiple apps. That's also why your battery drains.
How can i know which app is causing this drain??
Go into your settings and from there go to device maintenance. Hit the battery icon at the bottom left corner. Then hit the battery usage icon located under the estimated battery life time.
araelbenjie
