S8+ battery help?
neil123456
52
Had a look round the web and can't find the answer, does the bigger battery life in the s8+ lead to better battery life than the S8?
I have read that it does and some say that due to the bigger screen it results in about the same life of the S8.
I have both my s8 plus battery was awesome when phone was new but now battery life isn't anything at all to write home about, I'm pretty sure due to last few updates my battery life getting worse and worse.but compared to my wife's s8 hers last longer but she's not as much of a user like I am.when both were bought mine lasted longer so.I can't really tell you without using both at the same time.
There are also quite a few posts here on the same thing. You can't get a definitive answer unless a tech lab did a detailed test on both, and then it would only reflect lab conditions. If there is a difference it would be small and not worth dealing with.
FahadsTech
