Verizon Galaxy S8 S8/S8+ - Verizon Update
I also have issue with Verizon s8+ where hotspot crashes when trying to access hotspot security and advanced settings. Anyone else? Had it before update and after.
VVM still pauses for me. what a load of crap. a fix actually listed in changelog and it did nothing to fix it? who the actual hell is in charge of these things?!
although after reading through the Verizon help forums and their moderator responses, I'm not surprised there will need to be a fix for the fix
Did it break something else?
The fix for the VVM is a simple one for now.. It has to deal with Samsung Pay.
Just make sure you go to settings in samsung pay and under use favorite cards just turn off lock screen and home screen. I do have screen off turned on. That combination will keep VVM going and not shut off. If i try a different combination as in home screen on or lock screen on it cuts out my VVM.
Still doesn't work for me. Check if you still have Samsung Pay running in Memory background by pressing the multi-window button. Doesn't matter what the setting is as long as Samsung Pay is n the background VVM will function fine but once Samsung Pay is closed completely from memory, VVM will be wonky again
my 2 cents
alejandro109322
