s9 Won't fast charge. **PLEASE HELP**
Tarek Fahmi
11
(I have the exynos variant if that is at all relevant to the issue)
When i use the fast charging cable and brick that come with the s9, i get an estimated charge time of over 2 hours, and when i toggle fast charge on and off in the advanced battery settings, it doesnt change at all. With fast charging on or not. Could it be the cable?
Is it saying fast charging in the notification panel? If not then it is either the cable, the charger or the phone. All components should be under warranty from Samsung.
It says fast charging in the notification panel. When I toggle fast charging off in the advanced battery settings, the time remains the same. When i toggle it on again, still no difference. Really starting to **** me off.
How much battery is left when you start the fast charging? If the battery is low enough, it may take 2 hours of fast charging to fully charge it.
kurniaa
