SA Labs Equalizer for volume fix
  • Thread starter Thread starter budmonster
  • Start date Start date
B
budmonster
I know a lot of people found that Volume + fixed there speaker/notification/ringtone volume problem. For me Volume+ didn't work and also for a few others. I saw this over on XDA, Equalizer from SA Labs. You can find it in the Market here: https://market.android.com/details?...?t=W251bGwsMSwxLDEsIm9yZy5lcXVhbGl6ZXJhcHAiXQ
Here are the settings this user recommended, I tried them myself and volume on my phone is actually set to what it should have been in the first place. I didn't see this on here, tried searching. Maybe it can help someone else, good luck.
XDA thread: http://forum.xda-developers.com/showpost.php?p=20689993&postcount=1
Yeah, I didn't get much from Volume+ on mine, other than the speaker sounding like it's being overdriven.
Thanks, I'll give SA Labs a try!
Thanks, Budmonster! Volume+ had zero effect on any of my volumes. SA Labs Equalizer made the speaker volume sound 2x louder. Great find.
Works WAY better than Volume+. I think Volume+ Just has a placebo affect. You can definitely hear a difference with this app. The suggested settings are a bit high for my taste and seem to distort the sound. I have all first 5 levels at 10.0 db and the bass boost at 25% as suggested and it seems to be a lot louder without the speaker distortion. I just hope this doesn't cause the speaker to blow.
*EDIT* After playing with the app for a few minutes I have a question. Why does it not work unless I have Volume+ installed? I installed Volume+ first. Then this app and set it up. After uninstalling Volume+ the app stopped increasing the volume. Once I reinstalled Volume+ it began working again.
I've also set everything to 10.0db when I first set it up. Great minds think alike, eh?
I uninstalled Volume+ before installing this, and haven't had any issues. Try to uninstall both, and reinstall Equalizer.
*customized tapatalk signature*
Anyone running this for a few days can comment on battery usage? Since it's running constantly in the background.
On a side note this worked much better than volume + for me, as others have suggested.
I tried uninstalling both and reinstalling the Equalizer but I still had the same affect. I know that when I first installed Volume+ it said that it had to run something with the volume to make it work and seemed to over take a setting in the phone itself. I think that may be the problem and why it's not working without both installed.
Are you going into the menu and hitting store before you leave the app? If you just back out of the app after setting it up it drops all the settings and reverts back to 0db.
It looks like if you close the app the volume goes back down. Does this help speaker phone volume, too?
Just a heads up on Volume+, I have a db meter and it definitively increases the db level by +3 or whatever you set it to. Not saying it works for everyone but I confirmed it on mine.
You have to set it and go to settings and store it and don't back out - hit home.
Fixes all the sound issues!
Great find, This seems to work alot better for me.
I also find that setting it at 10-11, with 25% bass, sounds the best to me.
won't android's self regulating multi tasker kill this if it keeps running in the background? also, how much impact does it have on the battery since it's always running?
LiamHammett
