Samsung 15w Fast Wireless Charger
Hermes Hidayat
2,630
5
38
So i just got my Samsung 15w Fast Wireless Charger.
Things I found out :
1)Turns out the pad has holes all over the side(left,right and top from the SAMSUNG logo)to help with airflow to help cool the charging device.
2)The adaptor provided is the same as the one which came with the N10+.
3)AUTHENTIC ones will show matching S/N on both the box and charging pad.
4)Now users can schedule when to turn off Fast wireless charging(Settings - Device Care - Battery - 3 dots on top right corner - Settings - Fast wireless charging).
5)My N10+ gets hot(41 Degrees) when phone is charging and not in use.
Nice I just saw a review on it yesterday. So the adapter is 25W?
Wow! That's not bad. Do you notice charging speed compared to other wireless chargers(if you have one)
It charges faster. Around 20mins faster. During my time with my S10+. I remembered Fast Wireless Charge 2.0 to be as fast as wired charging.
Is that normal or is it defective?
It seems to be "normal" but i just tend to worry. Not saying that it'll explode but i just add an additional fan to help cool it. The fan is also rather loud. Louder than previous Samsung Wireless chargers.
I use AOD as my night clock so I just don't want it to overheat and explode in my face while I'm sleeping.
Yea I was using one of the older round ones and the newer style is a bit faster. I have never had my phone get hot yet on FC all night . I also have a 15W one in my car and even running Waze it keeps me at 100% and doesn't get hot at all. Maybe it's your Phone that is the issue and not the chargers. Also do you have a case that might have metal in it , they say that can cause heat .
I have tried it with 4 different cases. (OtterBox Defender, OtterBox Symmetry, Supcase UB Pro and Pitaka Aramid) they all go pass 40 degrees. But if i use Fast Wired 25W it doesnt go pass 40 degrees...
Should be no more than 45° Celcius or so. See my chart of a test I did a while back when I first got the phone. (Crossed out the meter URL because it broke after that.)
riaz491
