Samsung.com Pre-orders/Shipping Thread
Does anyone who already have the phone feel like the cable is too short? Do you think it's fine to use a non-Samsung cable? I still want to use the 25watt brick. At first I didnt think it helped but dsmn it does. ;)
Yes I feel their short that's why I use the Amazon basics USB C to USB C cord 9 ft Well worth the investment
Yeah, the cable is a little short. I ordered some longer ones from Amazon.
Never heard that it has to be 3.1. When using my 6ft cable the phone reads that it's fast charging.
requirements taken directly off a post here on the forum. "USB 3.1 Gen2 (5A) cables, which have USB Type-C connectors at each end"
this post from this thread. does this not apply to both Samsung charging bricks or only the the 45W?
https://forums.androidcentral.com/s...-disappointing-unfortunately.html#post6625721
45W chargers according to the standard charge by 15Vx3A=45W. The Note 10+ can handle only a maximum of 10Vx4.5A=45W, the way the Samsung custom 45W custom chargers work. Therefore your charger (which although 45W, is not Samsung) is only charging at (the maximum voltage the Note 10+ will take, which is 10V - look in ABOUT in your settings menu!), (and the maximum amperage your charger will output, which is probably 3A), so your highest wattage for the charging in your case would most likely be 30W (=10Vx3A). You should buy an in-line meter like I did and then you can see what is really going on. Try different cables too, the only cables guaranteed to work are those that are USB 3.1 Gen2 (5A) cables, which have USB Type-C connectors at each end (even a lousy adapter for the connector will sometimes disrupt the more complicated connection between the 45W power supply and the phone): https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU6634570
What color? I'm getting the white(cause I got a white phone) but I also like the black
White cause also my phone is white and I think it looks best in white. The view window is clear the rest are kind of colored.
I dont think USB-a to C do the fast charging my phone chargers faster with the usb c cable it came with..
I bought a cable that is usb c to usb c 3.0 but said it works with S10 so I'm hopeful I'll get something decent with it. plan to use it in my car for charging so I'm not sure it's going to help anything very much, but at least if I need it for the house I can use it and get a 3.1 2nd gen with usb c on both ends once they're common place. hate buying duplicate cords.
Any one got a made in Korea 10 plus..one of my friend got that and wondering what could be the difference..will quality be better than made in Vietnam?
gamersOnedge
