Samsung Desk Widget
Ditto. But honestly I turn it off completely. When I plug it in I verify my alarm is on and then hit the power button the turn the screen off as I dont want a blaring light in my face as well as I dont want my screen on all night.
Thanks! That makes sense.
Howdy all,
Long time lurker, finally decided to make it official like. But I do have a question. I have the dock and installed the software, but whenever i put it in the dock, the software never come up on it's own. From my understanding it was supposed to be automatic. Am I missing a configuration setting somewhere? Is it buried somewhere in the settings?
And I am also having the same issues with the volume buttons. So far, I have learned to set it right in front of the jack and slide it over the little bit it needs. I've been pondering a little to taking the dremel and making the present groove a little wider and deeper, but I don't know what is under it, if anything.
Howdy all,
I had a few issues with the software coming up initially but it was because I was exiting in and out of the software without actually closing the app. Try to open it from your app menu and close it again to make sure you kill the process (or see if it's running in your list of running apps) and then after that connect the dock and see if it resumes its automatic appearance...
Also, I too have "learned" how to maneuver my phone to not have the volume buttons affected by the dock, but it still triggers them sometimes... it's an incredibly annoying design flaw oversight! Shame on you Samsung and Sprint!
Is there a place you can go to change out the settings? I have a feeling something is "off". When I put my phone in the dock earlier, nothing came up. I just took it off to check a mesg that came in and put it back on and the Alarm+ app started. Other than checking the mesg, I did nothing else, so something is telling it when and when not to run the app and what app to run.
Djmanitas89
