Samsung fast wireless charging led indicator?
Blazeeofglory
222
Hi everyone!
So I had bought a wireless fast charging pad from samsung. I notice that when its charging it is solid blue. When its finished, it just flashes blue. My boyfriend has the regular wireless charger from samsung (not fast) and his turns solid green when its at 100 percent. Is the flashing blue normal for mine?
Flashing blue usually means it isn't lined up right and isnt charging. Check your box and see what it says.
I have the regular wireless charger and my LED is solid blue when charging and turns solid green when charged.
If the light is flashing blue that means it is not charging.
You'll need to reposition it. It turns green when your phone is fully charged.
Kind of off topic, but is it worth getting it to replace my Tylt Vu? Just wondering if there are any real benefits other than a bit faster charging time (I only use it overnight when I go to bed). Thanks!
Only benefit is speed. If you're using it overnight, won't really help much.
Thanks ... Trying to figure out something to use 30% off code for... doesn't seem like I'll find anyrhing. Probably a good thing since this phone broke the bank already ...
Grrr...the S View flip cover won't work with Tylt Vu to charge my phone (I just installed the cover yesterday) :( Does anyone know if S View cover will charge ok with Samsung wireless charger? Thanks.
gianfranco
