Samsung Galaxy Note 4 Already scratched the metal...
Just look at the metal ...it will have scratches . If other people with cases on it have it yours will as well
Yeah, that's why I didn't write it didn't have any scratches, but that I didn't notice any.
🔋from the Note 4✒ 📒
I bought a note 4 off eBay a couple days ago, the metal edges were pretty banged up. I taped off the screen very carefully with painters tape, make sure the corners were taped perfectly, removed the back, then sanded the shiny surfaces of the edges with 1000 grit automotive sandpaper. Worked like a charm, phone looks brand new. If you decide to try this, just go slow, be careful, and pay attention. There are several spots around the edges where a piece of plastic crosses over the metal, I assume they are parts of the antenna, avoid those while sanding.
I meant to quote this earlier. Do you have any pictures of after you sanded it?
Seriously guys. Mine has major scratches on right top and bottom corner and I DON'T care.
If all of you just ignored it, I believe you won't even noticed it when using.
And speaking of where I got my scratches, I used the metallic aluminum bumper for a test when I heard a frightening scratch. Was heartbroken but I will live. :/
Posted from my Note 4
Yup, I pretty much recently stopped giving an F. Just got a new case, well it comes tomorrow. If it scratches the phone, the way I think of it is, it's just adding to the collection.
Nazeer zaheen
