Samsung Galaxy Note 4 Does the Urban Armor Gear Case work with the Verizon Note 4? UAG
felloffthetruck
Trusted Member
Mar 31, 2013
8,616
24
38
Do the new UAG Note 4 cases have the elongated microphone hole on the bottom so it will work with the Verizon Note 4?
Thanks.
Re: Does the Urban Armor Gear Case work with the Verizon Note 4? UAG
Thanks, Breezy
Just went to order the Maverick and it is Sold Out again. :p
I can't get a case to save my life.
The case will work since the speaker hole is slotted on the bottom to accommodate all models. Great case!
Is the hole around the speaker level with the rest of the back? My Otterbox Commuter has a raised area around that cut out so it doesn't lay flat.
I'm considering the commuter. May I ask why it matters if the phone lays flat or not?
Using the S-Pen it helps if it lays flat...
I don't have a case yet, so it neither lays flat nor does it stay still while drawing. It never bothered me though, so It'll be interesting to see if it makes a positive difference.
For the record, this is the case I decided on until Trident releases a case for the Note 4 (Mid-November). It has feet on the back, which leads me to believe it'll lay flat.
Just got my Urban Armor case and it works and looks great with the Verizon Note 4. It was a tight fit so I am a little concerned I may have scratched the aluminum, which is bad since I like to change cases often. Love everything else about it though.
I asked that question here and the answer back was "h*ll on wheels".
It's not a picnic to get out, I can see a few micro scratches, but nothing really serious. Someone else mentioned they were able to get those out with some aluminum polish and a cloth.
MistyLove
